Heat transfer, Solid Mechanics and Laminar Flow
Posted 15 juil. 2014, 15:52 UTC−4 MEMS & Nanotechnology, Fluid & Heat, Heat Transfer & Phase Change, MEMS & Piezoelectric Devices, Microfluidics, Modeling Tools & Definitions, Parameters, Variables, & Functions, Structural Mechanics Version 4.4 0 Replies
What are the required physics to be used when designing a micropump that works using heat?
When the surface is being heated up, the liquid expands and pumps out.
It should be noticed that the micropump will deform also when it is being heated up.
So, what should I use in this case?
- Heat Transfer and Solid Mechanics.
- Heat transfer, Solid Mechanics and Laminar Flow.
Any suggestions?
Marwan
Hello Marwan Nafea
