Cyclic Dependencies in an AR coating
Hi all,
I am currently working on modeling an antireflection coating by building a model based off of the Plasmonic Wire Grating tutorial. I have attached the model, so I'll skip over the particulars of how its built. Every time I try to solve, the model generates an error -
"There are cyclic dependencies.
- Variable name: root.comp1.mat12.rfi.n11
Error in multiphysics compilation."
Anyone know what is going on?
4 Replies Last Post 1 janv. 2016, 10:49 UTC+1
Posted: 1 decade ago 22 juil. 2014, 21:16 UTC+2
Sorry forgot to attach the file.
Posted: 1 decade ago 22 mai 2015, 13:55 UTC+2
Hello Sahil Hasan, I have got the same problem when the version 4.3a is used. If you have solved your problem, could you please tell me the solution? Thanks in advance.
Saeed Mazrouei Sebdani
Posted: 1 decade ago 9 juin 2015, 18:11 UTC+2
hi,
could you solve your problem? i am facing the same problem. could you please help me ?
hi, could you solve your problem? i am facing the same problem. could you please help me ?
Posted: 10 years ago 1 janv. 2016, 10:49 UTC+1
Try to rename the variable n11 (for eg, n11a). Hope it works, for me it worked.
"There are cyclic dependencies. - Variable name: root.comp1.mat12.rfi.n11 Error in multiphysics compilation." Try to rename the variable n11 (for eg, n11a). Hope it works, for me it worked.
