transient analysis with harmonic point load
Posted 14 avr. 2010, 22:33 UTC−4 1 Reply
I am trying to model a ractangular plate driven by sinusoidal load with very high frequency (approximately
15000 Hz). What I want to get is the time dependent displacement of a certain point on my plate.
After defining a point load (F_z = sin(15000*2*pi*t)) I pick my solver parameters as follows:
Solver Parameters 0:0.0000001:0.001
(The reason why I pick such a small delta_t (0.0000001) is because the period of the applied load is 1/15000 seconds)
I leave the absolute and relative tolerance values as they are, i.e., 0.01 and 0.010 respectively.
After doing the meshing/solving I postprocess to get my time vs z_velocity plot at a certain point. The problem
is both the displacement and velocity plots are choppy and no matter how small I pick the delta_t (time
iteration) I get the same plots. How can that happen? I am expecting to get higher resolution in time as I
decrease the delta_t but that does not happen.
What am I missing? Can it be because of the tolerance values? Or maybe e-7 is too small for an accurate
transient analysis?
Any help is greatly appreciated.
transient analysis?
1 Reply Last Post 15 avr. 2010, 01:27 UTC−4
