Convergence versus meshing granularity
Posted 12 sept. 2014, 17:47 UTC−4 Computational Fluid Dynamics (CFD), Mesh, Studies & Solvers Version 4.4 2 Replies
                                                    I have noticed interesting behaviour in my models.
If the model will solve using a coarser mesh, it may not solve well using a finer mesh.
And although use of the boundary layer tool can reduce the wall lift-off, it does not necessarily reduce convergence time, and often can lead to convergence instabilities. Sometimes I can only add 2 boundary layers.
Also, if I use an initial field from a coarsely meshed solution, the convergence behaviour for the finer mesh will only begin to act erratically earlier.
I have noticed these effects using the k-epsilon and k-omega turbulence models.
2 Replies Last Post 24 sept. 2014, 03:24 UTC−4
