erro:Log of negative
Posted 27 sept. 2014, 14:53 UTC+2 Fluid & Heat, Heat Transfer & Phase Change, Chemical Reaction Engineering Version 4.4 0 Replies
I am getting the following error:
Log of negative
Function: log
Failed to evaluate variable
Variable: mod1.St, Defined as: ((mod1.p>=mod1.pea)*((cs-mod1.c)*(log((mod1.p/mod1.pea))*(exp(((-Ea)/(Rg*mod1.T)))*ka))))
Failed to evaluate expression
Expression: d((2*mod1.St*test(mod1.c)*pi*r)*(dvol),{test0})
Do you know how to fix this problem?
Thanks in advance for the comments
Hello Zhou Lu
