Shallow channel Approximation
Rajeendra Pemathilaka
I'm using COMSO 4.4 (Classkit version) and under laminar flow "use shallow channel approximation" option is missing. Actually it should be under Laminar flow------>turbulent model type-----> ***** . The whole turbulent model type part is missing. Is it something wrong with classkit version or different made for 4.4 version. Your comments are much appreciated!
1 Reply Last Post 6 oct. 2014, 13:38 UTC+2
Frank van Gool COMSOL Employee
Posted: 1 decade ago 6 oct. 2014, 13:38 UTC+2
Dear Rajeendra,
to be able to use the shallow channel approximation in 2D, you need the microfluidics or CFD module as shown in this list:
www.comsol.com/products/specifications/fluid-flow/
Probably your class kit does not support either of these modules. You can check this under "Menu>>File>>licensed and used products".
Frank
Dear Rajeendra, to be able to use the shallow channel approximation in 2D, you need the microfluidics or CFD module as shown in this list: http://www.comsol.com/products/specifications/fluid-flow/ Probably your class kit does not support either of these modules. You can check this under "Menu>>File>>licensed and used products". Best regards, Frank
