Model design from 2D axysimetric
Posted 7 oct. 2014, 14:37 UTC−4 Fluid & Heat, Computational Fluid Dynamics (CFD), Geometry Version 4.3a 1 Reply
Hello, how are you doing?
I´m facing a problem and would like to ask you if you have some hints about how to solve it. Recently i did a Comsol tutorial for a pipe flow simulation. In this tutorial it was used 2D axysimetric to build the pipe model. It was done building a rectangle and then they extrude it rotating that rectangle to form a cylindrical pipe. So they only build the mesh for the rectangle and solved the problem based on this mesh.
So my question is, there is a way to do something similar with rectangle cross section pipes? If it´s possible, can someone tell me how can i do this?
Thank you very much in advance
Houari
Houari
1 Reply Last Post 10 oct. 2014, 07:13 UTC−4
