Memory not released in COMSOL 3.5a
Posted 21 avr. 2010, 00:24 UTC−4 5 Replies
I'm trying to solve the lubrication equation (time dependent 4th order nonlinear PDE solved as a system of 2 nonlinear PDEs) using the General equation form in COMSOL 3.5a. the geometry is a simple droplet on a surface that results in around 30,000 DOF (quadratic elements). After initilization, the model solves ok up until higher times (~350, in steps of 0.1)where it gives me an <out of memory error> or <failed to find initial conditions>.
When looking at the task manager while the solution takes place it seems that COMSOL's memory consumption increases with time stepping until it reaches a max value (say 1.4GB in my computer) before failing. This memory does not get released by the program and restarting comsol becomes neccessary.
Has any one encountered this problem before? the program seems to work fine if other modulues are used (such as fluid flow).
Kind regards,
Laith
Kind regards,
Laith
5 Replies Last Post 22 avr. 2010, 14:42 UTC−4
