Power Cycling Life Prediction of 96.5Sn3Ag0.5Cu solder
Posted 12 oct. 2014, 07:13 UTC−4 Studies & Solvers, Structural Mechanics Version 4.4 1 Reply
Hi to all,
I'm trying to set up a FEM method in order to evaluate the number of cycles to failure for thermal fatigue in a power electronic device, composed by IGBTs and diodes.
The steps that I implemented are the following:
1- Input parameters: P_IGBT; P_diode; V_IGBT; V_diode.
2- Heat transfer in solids: Heat source 1: P_IGBT/V_IGBT; Heat source 2: P_diode/V_diode; T=25°C in baseplate of device;
3- Structural mechanics: Thermal expansion in all domains, with input temperature (ht) from the result of Heat transfer in solids; fixed constraint in baseplate;
4- Fatigue: based on strain; Selection of fatigue model: Smith-Watson-Topper criterion, elastic solution with intake restriction; field of solution: solid mechanics; fatigue parameters: sigma'f=276[MPa], b=-0.05; esp'f=0.325; c=-0.57; Young's modulus and Poisson's ratio from material; K'=304 [MPa]; n'= 0.086.
After the computation, I correcty visualize the maximum distribution temperature and von Mises stress, but I can't calculate the number of cycles to failure, in fact the expression ftg.ctf (or log10(ftg.ctf) returns to me the value 0.
Can you help me?
Best regards
Mario Nisi
Can you help me?
Best regards
Mario Nisi
1 Reply Last Post 17 oct. 2014, 02:25 UTC−4
