How to define Input Electromagnetic field with pre-defined phase?
Dear All,
I'm trying to simulate an interference-like phenomenon in COMSOL where I need to define an input wave (electric field or power) with pre-defined phase. So, I want to show that changing the input phase results in different interference results. However, I have noticed that using ports as input excitation has no effect (the input phase does not change).
Is there any way to define an input with an specific phase?
4 Replies Last Post 14 oct. 2014, 07:45 UTC+2
Posted: 1 decade ago 13 oct. 2014, 20:55 UTC+2
You can set the phase in a port, but it only has a meaning with a reference, e.g. a second port.
So, what is your phase reference?
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
You can set the phase in a port, but it only has a meaning with a reference, e.g. a second port. So, what is your phase reference? Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Nirmal Paudel COMSOL Employee
Posted: 1 decade ago 13 oct. 2014, 20:59 UTC+2
The following example demonstrate the way to excite different ports with predefined phase differences.
Hope this will be useful.
www.comsol.com/model/beam-steering-monopole-antenna-array-15737
Nirmal Paudel
COMSOL Employee
USA
The following example demonstrate the way to excite different ports with predefined phase differences. Hope this will be useful. http://www.comsol.com/model/beam-steering-monopole-antenna-array-15737 Nirmal Paudel -------------------------- COMSOL Employee USA
Posted: 1 decade ago 14 oct. 2014, 07:42 UTC+2
Dear Edgar,
Thanks alot, I hadn't paid attention to this fact. I just wanted to change the field maximum point in my device using the initial phase.
Thanks again
Dear Edgar, Thanks alot, I hadn't paid attention to this fact. I just wanted to change the field maximum point in my device using the initial phase. Thanks again
Posted: 1 decade ago 14 oct. 2014, 07:45 UTC+2
Dear Mr. Paudel,
This example helps me alot.
Thanks in advance for your kind help.
Hamed
Dear Mr. Paudel, This example helps me alot. Thanks in advance for your kind help. Hamed
