Jeff Hiller
COMSOL Employee
16 oct. 2014, 22:27 UTC+2
Hello Arjun,
If you can, use 4.4: we've introduced a Boolean Operation called "Partition" that lets you do what you want easily.
Hello Arjun,
16 oct. 2014, 23:17 UTC+2
Hi Jeff,
I appreciate your help. Unfortunately I only have access to 4.3b. Any tricks you recommend in this?
Arjun
Hi Jeff,
Arjun
Robert Koslover
Certified Consultant
17 oct. 2014, 04:13 UTC+2
Have you tried combining your geometry with various rectangular blocks (to separate it into the parts you want) using Boolean operations such as difference and intersection?
27 oct. 2014, 17:43 UTC+1
The partition function worked wonders.
I've been going through some literature on the COMSOL website regarding mesh quality. The write up mentions, "minimum mesh quality" as a good parameter to assess mesh quality. It also mentions that these parameters vary with respect to the different applications.
I'm currently working on a 3-D model that simulates microfluidic flow. I'm using an insanely fine mesh yet the minimum mesh quality is of the order e-4. I've ensured the growth-rate is limited to 1 but have the x-direction geometry scale set to 3. (the direction in which steep gradients occur)
Any ideas on which parameters might be a tell-tale sign of a good mesh for a micro-fluidic application?
Cheers
Cheers
