Hardware Question
Posted 13 nov. 2014, 12:03 UTC−5 Acoustics & Vibrations, Studies & Solvers, Structural Mechanics Version 4.3, Version 4.3a, Version 4.3b, Version 4.4 0 Replies
With that being said, is there a limit on the priority that should be placed on RAM/core when specifying out a system?
For instance, consider the following 2 systems:
System 1) 3 gHz 4-core cpu, 128 Gb Ram 8 dimms 2133 Hz
System 2) 3 gHz 8-core cpu, 128 Gb Ram 8 dimms 2133 Hz
Both have the same amount of same speed memory. Only difference is that system 1 has less processor cores to share the memory.
Would system 1 be capable of handling larger models due to more RAM/core?
If I'm using iterative solvers, I'm guessing they would be very close to being equivalent.
I mostly model fluid acoustic fields (with occasional structural mechanics), if that is pertinent information.
I would appreciate anyone's opinion on the matter.
Seth
Hello Hubert Hall
