2 simulation, 2 geometry
Posted 19 août 2009, 04:59 UTC−4 Version 4.1 2 Replies
Hi everybody.
I have a problem with a particular job I want to do with Comsol.
I have to run two different simulations, but in the first simulation I want Comsol to calculate the solution only for some subdomains, not for the entire geometry. Then I want to run a simulation which considers also the other part of the domain not included in the first one.
I’m using the Earth Science Module, axial symmetry 2D. In the first run I want to assign an initial stress state to my model due to its own weight. Then, in the second run, Comsol should use the results of the first run but it has also to consider the interaction with the other part of geometry in the model.
Is there the possibility to deactivate some elements (or an entire subdomain) I’m not considering in the first run?
Can someone help me?
Thanks everybody
Thanks everybody
2 Replies Last Post 24 janv. 2011, 11:41 UTC−5
