2 decades ago
10 mai 2010, 08:36 UTC+2
no need to mix up the threads with different subjects. I'ts not going to make me resonds more or less quickly, my repsonses rely on 1) available time as I'm doing this on my private time, 2) if I beleive I can give a reply, 3) if I have access to COMSOL.
You were unlucky, none matached this week-end ;)
But still, my reply is vague; I believe YES, because from the moment you can express it as PDE's , its solvable, but I'm not sure what to propose as approach, the question is really what are the physical phenomena required, the hammer effect is a wave propagation effect after an abrupt velocity change, at least in my understanding, and I'm not a fluidic specialist so I'm not feeling well enough informed/trained here. You should look through the litterature to identify the physics needed and then match that against what you have as comsol modules, and then decide how to mix the physics, possibly to add some PDE, if you are missing a module or some physical expressions.
BEst reply so far, but there are other better than me in fluidics around
have fn Comsoling
have fn Comsoling
2 decades ago
10 mai 2010, 12:33 UTC+2
thank you very much (^_^) sir...
