Geometry using mathematical function
I want draw exponential taper using mathematical function in comsol using 2D Axial Geometry.so,anybody can suggest how can I do this.?
4 Replies Last Post 28 janv. 2015, 15:49 UTC+1
Posted: 1 decade ago 2 janv. 2015, 09:13 UTC+1
I don't believe it is possible. You probably have to use a CAD software to draw that shape.
Posted: 1 decade ago 2 janv. 2015, 10:03 UTC+1
Krupali,
you can try a parametric curve. Its application is pretty straightforward.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Krupali, you can try a parametric curve. Its application is pretty straightforward. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago 28 janv. 2015, 10:26 UTC+1
Thank you sir for your reply.
But,It generates a message "singular edge detected"
Can you please help me how to solve this error?
Thank you sir for your reply. But,It generates a message "singular edge detected" Can you please help me how to solve this error?
Posted: 1 decade ago 28 janv. 2015, 15:49 UTC+1
I can only guess: maybe you have to combine this curve with other geometrical elements that finally result in a domain together.
Edgar J. Kaiser
www.emphys.com
I can only guess: maybe you have to combine this curve with other geometrical elements that finally result in a domain together. -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
