AC/DC Module
I am trying to model the electric field as a function of height over a PCB. However, in my simulations, the electric field strength is changing when I change the frequency. I am not sure if this should be the case. I am making one of the electrodes as a port and the other as ground. Can someone explain me why am I seeing the strength of the field change with frequency?
2 Replies Last Post 24 mai 2010, 19:50 UTC+2
Posted: 2 decades ago 22 mai 2010, 08:47 UTC+2
Are you in static or eigenfrequency or ..., pls provide slightly more info such asa version and module(s) used.
I agree that as first thoughts, in static, the field should not increase, if you are not enetering any other energy, but have you tried to check the energy balance ?
Have fun Comsoling
Hi Are you in static or eigenfrequency or ..., pls provide slightly more info such asa version and module(s) used. I agree that as first thoughts, in static, the field should not increase, if you are not enetering any other energy, but have you tried to check the energy balance ? Have fun Comsoling Ivar
Posted: 2 decades ago 24 mai 2010, 19:50 UTC+2
Hi Ivar,
Thanks for the reply.
I am using Quasi-Statics, Electric --> In-Plane electric currents.
Can I even input a frequency in the Statics, Electric mode? Also, what do you mean by checking the energy balance?
Piyush
Hi Ivar, Thanks for the reply. I am using Quasi-Statics, Electric --> In-Plane electric currents. Can I even input a frequency in the Statics, Electric mode? Also, what do you mean by checking the energy balance? Thanks, Piyush
