Quick Question about Geometry
I am modelling permanent magnetic fields but the north and south pole is aligned in the z-direction. However I'm only interested in its effect on the x-y plane. Is there a way to do that in a 2D geometry? Since it seems i can only define the "north-south" poles of the magnet in the x or y direction in 2D.
Thank you.
1 Reply Last Post 11 juin 2010, 11:27 UTC+2
Posted: 1 decade ago 11 juin 2010, 11:27 UTC+2
Albert,
I assume you are using 2D planar symmetry. You cannot define any physics along the z-axis because this would break the planar symmetry.
Best regards
Edgar
Albert, I assume you are using 2D planar symmetry. You cannot define any physics along the z-axis because this would break the planar symmetry. Best regards Edgar
