negative stress = compressive stress ???
Posted 21 juin 2010, 02:53 UTC−4 5 Replies
Thanks for your help.
So that means that the negative stress values (blue) in the picture are compressive stress?
Or expressed in another way:
What does the minus sign of a stress value mean?
1) direction of the stress vector in the coordinate system
2) compressive stress (negative value) in difference to tensile stress (positive value)
3) both
4) other
Christoph Mannal
June 20, 2010 9:10am UTC
I have a simple question. When my value of normal stress is negative, is it then a compressive stress in general. So if it is positive, is it then tensile stress?
Or does the minus and plus just mean in which direction the stress vector is pointing?
Thanks and kind regards!
C. Mannal
Reply | Reply with Quote | Send private message | Report Abuse
Moderator
June 20, 2010 5:28pm UTC in response to Christoph Mannal
Re: negative stress = compressive stress ?
what if you try something like this (its V4, check that it's the same in V3.5)
Attachments: StressSignTst.mph
Moderator
June 20, 2010 5:31pm UTC in response to Ivar KJELBERG
And here are the view (only that in V4 it's not easy to identify which legend corresponds to which graph, but as the countour is Von Mises and von Mises >0 you should be able to identify it still unambiguously)
Have fun Comsoling
Attachments: StressSign.JPG
5 Replies Last Post 2 déc. 2010, 01:19 UTC−5
