cantilever frequency response in a fluid
I need to simulate a cantilever which vibrates in a fluid (for instance water) and observe his frequency response.
To do that, I used 4 modules : 2 MEMS Plane Strain modules (1 for frequency response, 1 for fluid effect on the cantilever), 1 Mobile Mesh ALE module and the last is Incompressible Navier Stokes.
Except the MEMS Module for frequency response, all of the modules are transient analysis study.
Until now, when I plot the amplitude of the displacement, I get only the one which correspond to a cantilever in vaccum.
So I think there is a problem whit Navier Stokes module and parameters.
Anyone has an idea how to do this simulation ?
I used the version 3.5a of Comsol Multiphysic. I work with a 2D model
Thank you.
Teddy Maillot
6 Replies Last Post 13 avr. 2011, 19:05 UTC+2
Posted: 2 decades ago 23 juin 2010, 17:35 UTC+2
Hi Teddy,
give a look to the pdf file: FSI Analysis of Microcantilevers Vibrating in Fluid Environment.
You find it in the "Paper & Presentations" section.
All models are in 3D but I think it is quite easy to convert them in 2d. No ale module is employed and all analyses are of "Damped Eigenfrequency" type.
I hope this helps.
Alessandro
Hi Teddy, give a look to the pdf file: FSI Analysis of Microcantilevers Vibrating in Fluid Environment. You find it in the "Paper & Presentations" section. All models are in 3D but I think it is quite easy to convert them in 2d. No ale module is employed and all analyses are of "Damped Eigenfrequency" type. I hope this helps. Alessandro
Posted: 2 decades ago 23 juin 2010, 17:43 UTC+2
Hi Alessandro,
Thanks for this. I will take a look at it.
Teddy.
Hi Alessandro, Thanks for this. I will take a look at it. Teddy.
Posted: 2 decades ago 25 juin 2010, 16:06 UTC+2
I read the article but when I try to run the simulation, I get the error : singular matrix (with a 2D and a 3D model).
I didn't really understand how to replace the time derivatives by "*jomega_smsld" (page 5, paragraph 3) for the Navier Stokes module.
Thank you
Teddy.
Hi I read the article but when I try to run the simulation, I get the error : singular matrix (with a 2D and a 3D model). I didn't really understand how to replace the time derivatives by "*jomega_smsld" (page 5, paragraph 3) for the Navier Stokes module. Thank you Teddy.
Posted: 2 decades ago 25 juin 2010, 17:09 UTC+2
check the formula used for jomega (scalar variables if I remember right), and check the formulation of the time and harmonic development of the PDE in the doc.
The time derivative is replaced by the -j*w (check the sign convention) where w = omega is 2*pi*f where f is the frequency, it should ring a bell w.r.t. Laplace development as used i.e. in control, no ?
Have fun Comsoling
Hi check the formula used for jomega (scalar variables if I remember right), and check the formulation of the time and harmonic development of the PDE in the doc. The time derivative is replaced by the -j*w (check the sign convention) where w = omega is 2*pi*f where f is the frequency, it should ring a bell w.r.t. Laplace development as used i.e. in control, no ? Have fun Comsoling Ivar
Posted: 2 decades ago 30 juin 2010, 01:24 UTC+2
Hello Ivar,
I have one question that think you might know the answer, as I saw you replied many of the questions in Comsol forum. I do appreciate if you can help me out with my problem.
I am trying to model ALE transient system in 3D as I attached the file, I was wondering if you cna help me to find out how can I fix the "shape function" problem with my file.
"s" [as I guess] is the shape function for 2D simulation, but for 3D modeling, I tried the same rules and it face to error.
would you please have a look at my files?
Best and thank you in advance
Yasaman
Hello Ivar, I have one question that think you might know the answer, as I saw you replied many of the questions in Comsol forum. I do appreciate if you can help me out with my problem. I am trying to model ALE transient system in 3D as I attached the file, I was wondering if you cna help me to find out how can I fix the "shape function" problem with my file. "s" [as I guess] is the shape function for 2D simulation, but for 3D modeling, I tried the same rules and it face to error. would you please have a look at my files? Best and thank you in advance Yasaman
Posted: 1 decade ago 13 avr. 2011, 19:05 UTC+2
Dear Alessandro,
When simulating the microcantilever beam in water, did you apply the fluid-structure interaction boundary condition only on the top of the beam or on top and bottom? Thanks in advance!
Jin
Hi Teddy,
I hope this helps.
Alessandro
Dear Alessandro, When simulating the microcantilever beam in water, did you apply the fluid-structure interaction boundary condition only on the top of the beam or on top and bottom? Thanks in advance! Jin [QUOTE] Hi Teddy, give a look to the pdf file: FSI Analysis of Microcantilevers Vibrating in Fluid Environment. You find it in the "Paper & Presentations" section. All models are in 3D but I think it is quite easy to convert them in 2d. No ale module is employed and all analyses are of "Damped Eigenfrequency" type. I hope this helps. Alessandro [/QUOTE]
