Micro Thermoelectric Generator and circuit.
Hello
I have designed a Micro Thermoelectric Generator (μTEG) and now I want to connect it to a simple circuit with only a resistance load (RL) to know the power disipated by this resistance.
I think I set all terminals correctly to connect the circuit with the TEG but the circuit ignores the internal resistance of the TEG, so the TEG is like a ideal voltage source, how can I fix that and get a perfect coupling?
1 Reply Last Post 23 nov. 2015, 09:29 UTC+1
Hello Gabriel Capeáns
Posted: 10 years ago 23 nov. 2015, 09:29 UTC+1
Hello
I have see your question in the forum. In recent days, I have met the same question in the simulating progress. How do you set the resistance load to connect with the thermoelectric generator.
I am in preliminary stage, Waitting for your reply.
Hello I have see your question in the forum. In recent days, I have met the same question in the simulating progress. How do you set the resistance load to connect with the thermoelectric generator. I am in preliminary stage, Waitting for your reply.
