hypothetical example simulating deposition
Posted 13 avr. 2015, 03:45 UTC−4 Version 5.0 1 Reply
I'm trying to simulate the thermal stresses after a fabrication process in which I'm depositing one domain at a certain temperature, change the temperature, deposit another domain, change the temperature again, deposit another domain,... and then finally bring the whole structure to a final temperature.
I found a tutorial which I think may be pretty helpful for this.
www.comsol.com/model/thermal-stresses-in-a-layered-plate-273
I simulated the above scenario okay but I am having trouble doing so in 3D.
According to the simulation, the stress is non-constant only in the domain present initially and in the firsly deposited domain. in the domains that are deposited later, the stress is perfectly constant throughout the entirety of the domains. This does not seem correct to me (or is it?). Does anyone have a suggestion for how to improve my simulation? The only major change I think I did compared to the tutorial was I changed the matrix for the initial stress conditions (from 2D to 3D) and my boundary conditions are rollers where as the boundary conditions in the tutorial were for points and of the y-displacement-type.
File is attached.
Any help or suggestions would be greatly appreciated.
Thank you.
File is attached.
Thank you.
1 Reply Last Post 19 avr. 2015, 20:46 UTC−4
