using symmetry on single coil domain-benchmark test
Posted 22 avr. 2015, 11:04 UTC+2 Low-Frequency Electromagnetics Version 5.0 0 Replies
I compare 2 cases :1. A single coil (torus with gap feed) -magnetic flux density at center matches theory.
2. Half a torus (180 degree section) "stuck " to a magnetically insulated plane boundary fed by a terminal and ground)
Symmetry dictates that cases 1 and 2 should give the same result (actually case 2 should give half the value of case 1?)
Result :magnetic flux in case 2 is 25% lower than case 1
Please help
David
Hello David Segal
