Quality factor Vs. pressure for a cantilever.
Posted 24 avr. 2015, 16:29 UTC−4 MEMS & Nanotechnology, MEMS & Piezoelectric Devices Version 4.4 1 Reply
                                                    Our system is a cantilever. One of its extremes is fix and, under the other extreme that is free, there is an electrode for the excitation of the cantilever. This system is immersed in an air box. Tests are made using  “emi”.
Objectives/query:
1) We need to find the factor quality of the system, Q, in function of the box pressure containing our cantilever, from atmospheric pressure to very high vacuum. Which “physics” and “study” I can use to find it?
2) To obtain the response in frequency using the application “Frequency-Domain, Perturbation” it is necessary to consider an excitation voltage Vin = Vdc + Vac. Where Vac is a sine perturbation and Vdc a DC voltage. It is possible perform a study of response in frequency using only a Vac excitation?
Background:
I performed simulations of “Eigenfrequency” and “Frequency-Domain, Perturbation”. In the study of “Frequency-Domain, Perturbation” I used Rayleigh damping, where the parameters “alpha” and “beta” are calculated using equations of the “Frequency Response of a Biased Resonator - 3D” model (from the comsol library), assuming a value for Q. However, I need to find the value of Q changing the pressure of the box containing the cantilever/structure (vacuum chamber). Do you know how to do it?
                    Objectives/query:
Background:
1 Reply Last Post 24 avr. 2015, 17:06 UTC−4
