cell reynolds number
Posted 12 juil. 2010, 06:04 UTC−4 1 Reply
                                                    Hi there,
i'm using weakly compressible NS with heat transfer (transient). The flow is buoyancy-driven through heating.
I "experienced", that the temperature distribution, which i'm focussed on, depends on the mesh size in the domain where convection is active (+- 15K at 1000K. This is really annoying me. In this case refining the mesh causes higher temperatures. Further refinement has only little influence. So I don't know what is my criteria for knowing that the flow is modeled correctly.
I always look at the cell reynolds number, to be sure, that the flow is locally laminar. But I don't know if there exists a limit for the local Re-Number. cellRe<30? Using the GLS stabilization is needed for Re>2 for convergence. But is there any thumb rule for knowing: The boundary layer is correctly modeled within an error of about 1% (or 5% or whatever)? or things like that? What is your criteria for meshing flow domains? Your experience?
Thanks in advance!
Thanks in advance!
1 Reply Last Post 12 juil. 2010, 08:28 UTC−4
