Creating Pairs and Imprints
Hi!!
I am trying to simulate a fuel cell in COMSOL, so I have different subdomains that it is interesting for me to mesh them separately. Then, I have to use pairs and imprints. My problem is summarizing as follows:
- Two subdomains: 1 and 2
- Model A only in subdomain 1 and Model B only in subdomain 2
- A condition that depends on variables from Model B must be specified for Model A in the boundary that separates both subdomains and viceversa.
If I didn't use pairs, there would be no problem because the boundary belongs to the two regions involved. However, if I use pairs I get two different boundaries, one corresponding to the subdomain 1 and another corresponding to the subdomain 2. These boundaries are coupled using the pair option, but it is not active because the two subdomains don't have a model in common, so I have to specify the boundary condition for model A on its corresponding surface and the same for model B. If I try to solve, I get an error because variables from model A don´t exist in subdomain 2.
Does it have a solution, or is it impossible to create pairs in this case?
1 Reply Last Post 13 juil. 2010, 22:37 UTC+2
Posted: 2 decades ago 13 juil. 2010, 22:37 UTC+2
I believe you should use extrusion coupling variables, and express your boundary conditions as an addition weak form expression along the common boundary. The former alloews you to define global variables that have meaning in the other application mode / physics
Check the way COMSOL sets up boundary consitions for an assembly with pairs and the same physics, by studying the "Physics - Equation settings ..."
Hi I believe you should use extrusion coupling variables, and express your boundary conditions as an addition weak form expression along the common boundary. The former alloews you to define global variables that have meaning in the other application mode / physics Check the way COMSOL sets up boundary consitions for an assembly with pairs and the same physics, by studying the "Physics - Equation settings ..." Good luck Ivar
