Geometry building differently during Batch Sweeps than in individual simulations
Posted 12 mai 2015, 15:44 UTC−4 Geometry, Studies & Solvers Version 5.0 3 Replies
I have a geometry of a V-antenna which builds properly as a function of angle ("del") when simulated individually; however, when run under a batch sweep (of del) the geometry does not resolve the same way.
I open a solved batched model, and instead of a V-shaped antenna with the given axis angle, I get a shape that looks like the antennae have collapsed onto themselves. I then click on "Build All" (which uses the intended batch parameter) and the geometry then reverts to the intended shape! There are no errors, but there is a grey asterisk next to one of the transformations (Rotate) in the post-run model, as well as next to Solution 1. I have not been able to pull any other warnings/errors from the simulation.
Any thoughts why it would build properly for a single simulation but not for a batch?? Is there an issue with using [deg] and [rad] units? I have the geometry and input parameters set to [deg], but the batch converts to [rad]. Nevertheless, individual simulations will resolve [rad], so I do not think this is the issue...
-Ado
Hello Bryan Adomanis
