Plot streamlines in matlab
Hi All,
Does anybody know how to extract velocity field (e.g. laminar flow) and plot streamlines in matlab? I am still playing but no luck so far.
Danial
2 Replies Last Post 16 août 2010, 16:36 UTC+2
Posted: 2 decades ago 23 juil. 2010, 22:35 UTC+2
Hi Danial,
I have had luck using the following approach (4.0), though there may be better ways to go about it:
1. Use mpheval command to obtain grid point coordinates and corresponding velocities
2. Use meshgrid command to create regular coordinate grid for plotting
3. Use TriScatteredInterp command to obtain velocities at coordinates generated by meshgrid command
4. Use streamline command to generate and plot streamlines
A little clunky, but it seems to work. If you come up with a better approach, please let me know.
Paul
Hi Danial, I have had luck using the following approach (4.0), though there may be better ways to go about it: 1. Use mpheval command to obtain grid point coordinates and corresponding velocities 2. Use meshgrid command to create regular coordinate grid for plotting 3. Use TriScatteredInterp command to obtain velocities at coordinates generated by meshgrid command 4. Use streamline command to generate and plot streamlines A little clunky, but it seems to work. If you come up with a better approach, please let me know. Paul
Posted: 2 decades ago 16 août 2010, 16:36 UTC+2
Hi Danial,
Paul
Hi Paul,
Do you have a code snippet I can check? That will save a lot of time debugging.
Danial
[QUOTE] Hi Danial, I have had luck using the following approach (4.0), though there may be better ways to go about it: 1. Use mpheval command to obtain grid point coordinates and corresponding velocities 2. Use meshgrid command to create regular coordinate grid for plotting 3. Use TriScatteredInterp command to obtain velocities at coordinates generated by meshgrid command 4. Use streamline command to generate and plot streamlines A little clunky, but it seems to work. If you come up with a better approach, please let me know. Paul [/QUOTE] Hi Paul, Do you have a code snippet I can check? That will save a lot of time debugging. Best, Danial
