Extracting data from COMSOL
Hello All
I just want to know how to extract data from COMSOL and then plotting graph in EXCEL sheet.
For example if I am trying to study transmittance with wavelength, then how to get the data into EXCEL.
2 Replies Last Post 23 juin 2015, 12:32 UTC+2
Posted: 1 decade ago 23 juin 2015, 09:15 UTC+2
Use the derived data sets to get the values for specific parameters that you need and use the export option under results to save the datas to a format easily recognizable by excel.
Posted: 1 decade ago 23 juin 2015, 12:32 UTC+2
Hi Kalpana
You can save data from most tables in Comsol. If you wish to save the data directly into an Excel file you need LiveLink for Excel:
www.comsol.com/livelink-for-excel
Using LiveLink for Excel you can also simply load the COMSOL model into Excel using VBA and extract exactly the data you need into VBA variables and/or Excel sheets.
Lars Gregersen
Comsol Denmark
Hi Kalpana You can save data from most tables in Comsol. If you wish to save the data directly into an Excel file you need LiveLink for Excel: http://www.comsol.com/livelink-for-excel Using LiveLink for Excel you can also simply load the COMSOL model into Excel using VBA and extract exactly the data you need into VBA variables and/or Excel sheets. -- Lars Gregersen Comsol Denmark
