MSc project using COMSOL
I am currently doing my MSc project in Teesside University and having some problems regarding the COMSOL 3.5. Therefore, I wrote to you and hoping that you can provide some guidiances.
The problem is that I cannot decide which model should I choose to simulate my model. The basic idea of my project is using COMSOL to analysis the residual stress on alloy plate before and after the welding. The University only have a student version of your software and could only provide Heat Transfer and Electro-thermal interaction models.
I was trying to follow a tutorial on the company website called "Friction Stir Welding" (see attached) and could not find the same model on uni's computer. Should I ask for a higher level license or just find another similar models in the COMSOL?
The models, which are saved as both IGES and Solidworks part files, are also attached. My idea is creating a crack (regardless of shape, a straight line shaped crack will be just fine) and do the simulation.
Thank you for your time and hope to see your reply as soon as possible.
Best Regards
0 Replies Last Post 11 août 2010, 16:15 UTC+2
Hello Awad Mohammed
