velocity field and interface shape quistion
Posted 7 juil. 2015, 20:29 UTC−4 Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD) Version 5.0 0 Replies
Temperatures field solution look like fine but both velocity field and interface shape it’s doesn’t well, probably I should put the factor of shape but a doesn’t know where, it will be very if your help in my in this field of my work to get correct result of velocity field and correct shape of interface.
There isn’t problem if you need my file I will send it to you
Thinks
Hello Fouad Kerkar
