2D motion (rotation)
Posted 13 août 2010, 15:02 UTC−4 Version 3.5a 2 Replies
I am using Comsol Multiphysics V4.
I am trying to build a model where a oval rotates. Then I will add a flow-solid interaction in order to analize how this motion affects the flow (Diesel).
The problem that I have is when I am setting up this motion.
I have created a 2D Solid Mechanic time-dependent model. Then I have drawn a rectangle and a elipse inside. The next step is from an union and then apply materials and meshing.
I have set up "w" as angular velocity with a 1[rad/s] value in global definitions and then, in initial value I have specified Velocity fied -y*w for X and x*w for Y. I have also tryed to specify this angular velocity as prescibed velocity with the same result.
The solver seems Ok but when I plot my 3sec. analysis I can´t see any motion in the elipse.
I would really appreciate some help with this problem.
Hello Borja Navas
