Can't use parameter as frequency in boundary mode analysis
I'm trying to do a boundary mode analysis. If I type in a numeric frequency under "Mode analysis frequency" it works. But if I put "c_const/lambda" in for frequency, it says failed to evaluate variable even though lambda is defined in Global->Definitions. Even if I define a variable "foo" as c_const/lambda in Global -> Definitions, and can see the correct numeric value calculated there, if I use this parameter "foo" for analysis frequency, it fails.
Is this a bug, or am I misunderstanding something?
1 Reply Last Post 31 juil. 2015, 17:41 UTC+2
Posted: 1 decade ago 31 juil. 2015, 17:41 UTC+2
Hi Chris, I have the same problem! Did you find a solution?
Edit: I figured it out! You can control the value in "Mode analysis frequency" through MATLAB, by feeding a calculated value to the parameter.
Cheers!
Hi Chris, I have the same problem! Did you find a solution? Edit: I figured it out! You can control the value in "Mode analysis frequency" through MATLAB, by feeding a calculated value to the parameter. Cheers!
