Young's modulus E from Matweb.com
Posted 21 juil. 2015, 03:25 UTC−4 Materials Version 5.0 0 Replies
I would like to perform a modal analysis of an artificial bone (Cylinder), I have found the material parameters at MatWeb.
www.matweb.com/search/DataSheet.aspx?MatGUID=f7a64cd5a3534bf0a85d836da650f022
Density: 0.160 [g/cm^3]
Poissons ratio: 0.30
Young's modulus: 86[MPa] --> Tensile Modulus 0.0860 GPa
is that correct? Because the simulated values do not match with the real measurements ;(
Thank you for your help,
Thomas
Hello Thomas Bender
