Limiting current from Rotating Disk Electrode - Simulation doesn't match theory
Posted 19 août 2015, 17:37 UTC−4 Computational Fluid Dynamics (CFD), Electrochemistry, Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers Version 5.1 3 Replies
I am having an problem getting a value for the current at an electrode, that is being rotated in solution, that would be expected from theory.
The Levich equation ( en.wikipedia.org/wiki/Levich_equation ) models the diffusion and solution flow conditions around a Rotating disk electrode (RDE). The Levich equation gives the height of the sigmoidal wave observed in rotating disk voltammetry, or the limiting current. The limiting current can be approached, for example, by increasing the electric potential or decreasing the rate of mass transfer to the electrode. The RDE reduces the rate of mass transfer through induced flux and is equivalent to a silent solution at steady state.
I began with model library. I found the microdisk volatmmetry model. This model shows the limiting current as the applied potential is changed. I added swirl flow and got rid of the infinite boundary domain because the laminar flow physics did not allow me to select it. I am integrating the local current density along the electrode and revolving around the z axis (elan.iloc_er1*r*pi*2). this does not match the expected solution from the Levich equation. Also the current applied will result in the maximum current for this system.
What am I doing wrong? I've been at this for a while and have had no luck at all.
3 Replies Last Post 25 août 2015, 01:53 UTC−4
