some questions about surface tension between deform solid and liquid
Posted 2 sept. 2015, 12:05 UTC−4 Fluid & Heat Version 5.0 0 Replies
My model is that there is groove in elastic solid, and water is in groove. Stretch the solid, and the solid then the groove will be deformed. I wish I could see the contact angle at solid wall and the the surface tension's influence to the solid's deformaton.
Hello Si Chen
