Simple structural mechanics model does not converge
unfortunately I can't find the reason, why my simple mechanical model does not converge. Can someone help? Thank you.
Kind regards,
Levin
3 Replies Last Post 4 sept. 2015, 12:57 UTC+2
Posted: 10 years ago 3 sept. 2015, 18:58 UTC+2
Hi Levin,
I increased the tolerance factor in the 'Fully Coupled' node from 1 to 10 and it solves. This issue may arise from the large aspect ratio of the long thin beam.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Levin, I increased the tolerance factor in the 'Fully Coupled' node from 1 to 10 and it solves. This issue may arise from the large aspect ratio of the long thin beam. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 10 years ago 4 sept. 2015, 09:04 UTC+2
The model is ill-conditioned because it is undamped and the frequency response sweep passes close to a natural frequency. The solution exactly at a eigenfrequency is infinite, meaning that the dynamic stiffness matrix is singular there.
Edgar's solution makes it possible to solve somewhat closer to the singular point because the ill-conditioning check is modified somewhat, but it does not address the underlying problem.
Henrik
Hi, The model is ill-conditioned because it is undamped and the frequency response sweep passes close to a natural frequency. The solution exactly at a eigenfrequency is infinite, meaning that the dynamic stiffness matrix is singular there. Edgar's solution makes it possible to solve somewhat closer to the singular point because the ill-conditioning check is modified somewhat, but it does not address the underlying problem. Regards, Henrik
Posted: 10 years ago 4 sept. 2015, 12:57 UTC+2
... yes the damping, I miss it at times, something to be looked at first ...
Edgar J. Kaiser
www.emphys.com
... yes the damping, I miss it at times, something to be looked at first ... -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
