Heat transfer problem - Wrong Solution due to Heat flux boundary condition problem
Posted 7 sept. 2015, 13:33 UTC+2 Heat Transfer & Phase Change, Studies & Solvers Version 4.3 1 Reply
I'm doing a simulation of a channel flow with thick walls to understand the differences between macro scale and micro scale effects. When I impose an heat flux boundary condition with a certain value, and after the simulation runs through, I check the surface where I imposed the B.C and the amount of heat that is comming through is about 30 times higher then the one I imposed. Hope i've been has clear has possible.
The file is too big to be attached, so i followed your procedure and put the file in the following director so you can check it, ftp://ftp.comsol.com/incoming/COMSOL_FORUM_QUESTION.mph
Fill free to check the model and see if there is any error in mine implementation.
Duarte Albuquerque
Duarte Albuquerque
1 Reply Last Post 9 sept. 2015, 14:06 UTC+2
