if/else syntax for geometry
Posted 11 sept. 2015, 12:30 UTC−4 Geometry Version 4.4, Version 5.1 0 Replies
i had an array of cylindrical pillar on a surface placed at equal distances, the distance between pillar and edge of the surface depends on the surface dimensions.
Now i want to build a sub-pillars based on location of the pillar(s). If there is enough distance before the pillar to accommodate a sub-pillar, then the array of sub-pillars starts before the pillar.If there is no enough space the its starts after the pillar.
Please help me in building this. I think i can do this buy if /else programming but im confused about the syntax of it. (i build pillars by extrusion of work plane).
Thanks in advance.
Hello Pradeep
