Jeff Hiller
COMSOL Employee
10 years ago
14 sept. 2015, 19:53 UTC+2
In COMSOL, capabilities from all Modules can always be coupled within a single model file.
8 years ago
29 août 2017, 18:45 UTC+2
Hi everybody,
I just found this thread that resemble very much my problem, therefore I will ask a question here, instead starting a new one.
When I tried to combine "solid mechanics" with "RF" module, I got this message in the multiphysics window:
"No coupling features are available for the selected physics interfaces".
So, how do I simulate piezoelectric material coupled to electromagnetic waves? Is there a way to couple those equation?
Hi everybody,
Jeff Hiller
COMSOL Employee
8 years ago
29 août 2017, 20:13 UTC+2
Updated:
8 years ago
30 août 2017, 14:13 UTC+2
The Multiphysics branch only contains some pre-implemented couplings. There are many other ways you could couple physics together that the Multiphysics node does not cover, the most obvious one being to have a variable from one physics appearing in the equation governing another physics. Bear in mind that in the COMSOL interface, in your physics settings, all text fields can contain mathematical expressions, not just constant values. You can use that capability to, for instance, in your case, set up a mechanical load that depends on your EM solution in an unusual way, or to make an EM material property depend on the mechanical strains in some custom way.
8 years ago
31 août 2017, 10:57 UTC+2
Great, I did not know this possibility. I will try it.
Marco
Marco
8 years ago
27 sept. 2017, 12:23 UTC+2
Hi everyone,
I also have somewhat a similar situation. I have simulated doped ZnS in chemical specie transpor module. And now, i want to use this same structure to determine its absorption profile using RF module. 1) How can i import the doped profile as geometry material now for electric field simulation. And will software take into account the doped elements(Mn and Sn) as well? 2) Or i have to place some combined optical properties as input parameters?
Hi everyone,
