2 decades ago
10 sept. 2010, 04:14 UTC−4
Hi Cristina,
for what concerns your first question, i can say that the equations are the same if the absorption coefficient "a" in your original Helmholtz problem is zero.
I think the version of Neumann BC proposed by Comsol v4 is slightly more general than the one found in v3.5.
For what concerns instead your second question, you find some explanation in page range 248 - 256 of pdf file for the v3.5 modeling guide.
If you want to know what equation is currenlty implemented in your model, i think the best thing to do is to see the equation system (in v3.5) or activate the equation view (v4.0).
Another advice is to read carefully the chapter PDE, Energy and Weak formulation of reference guide of v4.0. This part didn't exist in previous versions and i think it is written in a very clear manner. You will find there the explanations about the inclusion of BCs in a model.
I hope this helps.
Hi!
Alessandro
Hi Cristina,
I hope this helps.
Hi!
Alessandro
14 sept. 2010, 05:50 UTC−4
First of all, thank you very much Alessando Ricci for your quick reply. As you suggested me I have been reading the manuals for both versions and I got some conclusions (lets see if I am right or not):
1) Regarding the Neumann boundary condition, the main difference between both versions (3.4 and 4.0) is that in 3.4 the Neumann boundary condition is more general because of the term qu (in fact, as it is said in the manual, this generalized Neumann condition is often called mixed boundary condition).
2) If we focus in 4.0 version, I think there should be a mistake in the way the boundary condition is shown in the "question tab" of the program interface.
The manual says the boundary condition (for a scalar coefficient PDE equation) is:
n•(cgradient(u)+ ?u-?)=g
We are using the predefined Helmholtz equation so ?= ?=0 and therefore the boundary condition should be:
n•(cgradient(u))=g
However, in the equation tab of the program it appears: -n•(-cgradient(u)-au+ ?)=g, so for the Helmholtz PDE we have (?= ?=0) :
-n•(-cgradient(u)-au)=g
with a=absorption coefficient (which should be defined in Helmholtz PDE).
I suppose there is a typo (it should be written ? instead of a), so I assume that the program is not considering the absorption coefficient in Neumann condition. Besides, the “dot product” would not be right because au is a scalar number not a vector. Does anyone agree with me?
I hope this time all the symbols in the equations are shown properly.
Cristina
n•(cgradient(u))=g
Cristina
14 sept. 2010, 16:43 UTC−4
I do not believe the V4 Neumann conditions are less general, thay have been rewritten slightly differently (without te "h" matrix, but by rearranging the equations you should arrive to the same cases, and in many (all ?) physics there are a few new sub-node entries to help.
For the potential typo in the equations, I have problems to follow, as most of the special characters seem to end up as "?" on my screen and I'm not managing to differentiat all the ? from each other ;)
15 sept. 2010, 04:22 UTC−4
Hi Ivar,
I am really sorry about the problem with the special characters, to avoid that I use this time words instead of those characters. Just to make it clear:
alfa= conservative flux convection coefficient
gamma= conservative flux source term
c= diffusion coefficient
g= boundary source term
a= absorption coefficient
n= unit normal vector
n•(cgradient(u)+ alfau-gamma)=g
We are using the predefined Helmholtz equation so alfa= gamma=0 and therefore the boundary condition should be:
n•(cgradient(u))=g
However, in the equation tab of the program it appears: -n•(-cgradient(u)-au+ gamma)=g, so for the Helmholtz PDE we have (alfa= gamma=0) :
I suppose there is a typo (it should be written alfa instead of a), so I assume that the program is not considering the absorption coefficient in Neumann condition. Besides, the “dot product” would not be right because au is a scalar number not a vector.
I would like to know if I am right or not because maybe there is something that I am missing or that I just do not understand.
Hopefully this time no “?” symbols appear.
Cristina
Hi Ivar,
n•(cgradient(u))=g
Cristina
8 août 2013, 10:39 UTC−4
Hi Cristina
This is Homa, I am building a model with Helmholtz equation and need to make Neumann boundary condition for a 3D situation with 3 variables, I do not how can I math the equation with what comsol has. I was wondering if I can take a look on your model if you have done this in 3D ! I really appreciate it
Regards
Homa
Hi Cristina
Regards
Homa
