How to add the certain force on the free surface ?
The problem is that:
I want to simulate a electrohydrodynamic (EHD) phenomenone , a nozzle with full water in a electrostatic field, the the water is polarized and deformed the Taylor cone. The models include the level set -laminar flow and electrostatic.The coupling variables is Fx and Fy, which depends on the surface charge density and electric field. The force only at the the surface existed. How to define this force? in another word, it's maybe a universal problem that, the Maxwell surface tension how to act on the free surface.
Thank you.
abubob
5 Replies Last Post 29 avr. 2016, 15:26 UTC+2
Hello Bu Ningbin
Posted: 1 decade ago 21 mars 2011, 12:06 UTC+1
Dear abubob...
I saw your question on the comsol forum. I am working exactly with the same kind of modeling but I could not find so far any good example with Comsol. I understood you are working with cone-jet mode. I am trying to model the simple-jet, which is the same with higher flows. Maybe we could discuss a bit and see if we can help eachother to find our way using Comsol. Please let me know if you would like to talk a bit further about this.
Kind regards
Luewton Lemos (luewtonlemos@gmail.com)
Dear abubob... I saw your question on the comsol forum. I am working exactly with the same kind of modeling but I could not find so far any good example with Comsol. I understood you are working with cone-jet mode. I am trying to model the simple-jet, which is the same with higher flows. Maybe we could discuss a bit and see if we can help eachother to find our way using Comsol. Please let me know if you would like to talk a bit further about this. Kind regards Luewton Lemos (luewtonlemos@gmail.com)
Posted: 1 decade ago 22 mars 2011, 02:01 UTC+1
Dear Luewton Lemos
I'am glad to talk with you. In the past months,I have simulated the cone, but the problem is also existed.The following examples are useful, inkjet nozzle. In simulation, the interface is a thin layer, the physcics parameters should be smooth( density ,visicosity , permitivity) , the div of Maxwell tensor is body force, so the whole regions,can add this force, but only the interface is valid. Another problem is the convergence. The solver should be adjusted, I'm working for this.If you have any questions, we can talk together. Good luck.
bu ningbin
Dear Luewton Lemos I'am glad to talk with you. In the past months,I have simulated the cone, but the problem is also existed.The following examples are useful, inkjet nozzle. In simulation, the interface is a thin layer, the physcics parameters should be smooth( density ,visicosity , permitivity) , the div of Maxwell tensor is body force, so the whole regions,can add this force, but only the interface is valid. Another problem is the convergence. The solver should be adjusted, I'm working for this.If you have any questions, we can talk together. Good luck. bu ningbin
Posted: 1 decade ago 5 août 2011, 08:29 UTC+2
I am new to this Comsol, as well as finite element simulation, just graduate form degree, now working on electrospray as well. I am still beating around the bush, try to understand the Physics that can be used in electrospray. Mind anyone me give me suggestions? Although Comsol supposed to give friendly GUI but no in electrospray, which deals with electrophoresis with two phase flow, as you mentioned the surface force on droplets and being charged.
Hi, I am new to this Comsol, as well as finite element simulation, just graduate form degree, now working on electrospray as well. I am still beating around the bush, try to understand the Physics that can be used in electrospray. Mind anyone me give me suggestions? Although Comsol supposed to give friendly GUI but no in electrospray, which deals with electrophoresis with two phase flow, as you mentioned the surface force on droplets and being charged.
Posted: 1 decade ago 17 juil. 2012, 22:43 UTC+2
Hi Bu
I am working on the same problem.
How did you manage to model the leaky feature of the jet? Did you use electric current (ec) instead of electrostatic? Did your result match what Taylor got in his 1964 paper?
Many thanks
Ahmed
Hi Bu I am working on the same problem. How did you manage to model the leaky feature of the jet? Did you use electric current (ec) instead of electrostatic? Did your result match what Taylor got in his 1964 paper? Many thanks Ahmed
Posted: 9 years ago 29 avr. 2016, 15:26 UTC+2
So I am wondering if you still remember how did simulate this E-jet model? Did you get the model?
