Charge Conservation overrides Semiconductor Module Properties
Posted 6 nov. 2015, 16:52 UTC−5 Semiconductor Devices, Materials Version 4.4 0 Replies
I'm setting up a MOSFET design containing SRH recombination and the 4 metal contacts (source, drain, gate, and base). Since this does not operate in the same way as the silicon MOSFET, the creation of a channel relies on polarization of a heteorjunction essentially, extending the relation D=ε0*E+P.
Since this cannot be defined in the Continuity/Heterojunction property, the only way I have found to accomplish this is to enforce the Charge Conservation boundary (Semiconductor -> Electrostatics -> Charge Conservation) and change the Constitutive relation to Polarization. The problem is that by adding a Charge Conservation property, it now renders all of my metal contacts as unapplicable. I have tried enforcing Charge Conservation on all layers as well as only on the layer which is polarized but it still causes this problem.
Has anyone encountered this before? I feel that an extensive overview of the Semiconductor module would clearly demonstrate why this doesn't make sense but at the moment I'm stuck.
Hello Christopher Lashway
