Plot the results of multiple time steps in one graph
I would like to plot the 2D contour plots of different time steps in one graph, is it possible? For example, in a time-dependent FSI model, at t=0.1s, I plot colour contour with an expression: solid.mises>100, which shows the regions have stress larger than 100 Pa in different colour. With the same expression, I plot the graph for t=0.2s. They have different parts that have stress>100 Pa, which means I cannot see the failed zones appears at t=0.1s. Is there any way that I can plot the them in one graph, showing the results of all time steps? Thanks a lot for any help.
Tianhang
7 Replies Last Post 21 déc. 2015, 00:11 UTC+1
Posted: 10 years ago 19 nov. 2015, 07:23 UTC+1
For advanced post-processing you can use, e.g. Matlab. Export your model in Matlab code (*.m) and you can edit that code according to your needs.
BR
Lasse
For advanced post-processing you can use, e.g. Matlab. Export your model in Matlab code (*.m) and you can edit that code according to your needs. BR Lasse
Posted: 10 years ago 19 nov. 2015, 08:31 UTC+1
I don't understand exactly what you want to do, but maybe you can use a Parametric 2D data set: By using this data set you get a 3D space where time is the third dimension. By using e.g. surface or contour plots on the parametric data set you can see all times at once.
Posted: 10 years ago 19 nov. 2015, 23:51 UTC+1
Hi Lasse,
Thank you very much for your suggestion.
Tianhang
Hi Lasse, Thank you very much for your suggestion. Regards, Tianhang
Posted: 10 years ago 20 nov. 2015, 00:13 UTC+1
Hi Gunnar,
Thank you very much for the help. I tried your suggestion, and it worked. I can plot a 3D graph showing all time steps. However, as I have got more than 10 time steps, I could not clearly visualize the results in the middle range, even if I made them transparency. Is there a way to plot the results on a 2D graph? Thanks.
Tianhang
Hi Gunnar, Thank you very much for the help. I tried your suggestion, and it worked. I can plot a 3D graph showing all time steps. However, as I have got more than 10 time steps, I could not clearly visualize the results in the middle range, even if I made them transparency. Is there a way to plot the results on a 2D graph? Thanks. Tianhang
Posted: 10 years ago 23 nov. 2015, 14:02 UTC+1
You can use a 3D contour plot pointing to the parametric extrusion data set and use a view that is chosen such that all the 2D slices coincide: Click on "Go to XY View" in the graphics window's toolbar. Then go to the view's camera node, probably located in Components 1 > Definitions > View 1 > Camera, and change Projection to Orthographic. Click Update in the settings window's toolbar.
Posted: 10 years ago 24 nov. 2015, 01:22 UTC+1
Thank you very much for the help, Gunnar.
Posted: 10 years ago 21 déc. 2015, 00:11 UTC+1
Hi Lasse,
Is it possible for you to further instruct how to do that in Matlab? For example, to return the largest value of a variable during a time-dependent study (for each point in the domain)? Thanks a lot.
Albert
Hi Lasse, Is it possible for you to further instruct how to do that in Matlab? For example, to return the largest value of a variable during a time-dependent study (for each point in the domain)? Thanks a lot. Regards, Albert
