2 decades ago
22 sept. 2010, 14:32 UTC−4
In V4 I would suggest that you look at a "Definitons Probe Plot", and the corresponding explanations in the doc
2 decades ago
22 sept. 2010, 15:07 UTC−4
thanks for your reply,
But unfortunately I don't have the possibility to use V4,Do you have any advice that works in 3.5a?
Regards'
Azar
Regards'
Azar
2 decades ago
22 sept. 2010, 15:30 UTC−4
you have also postprocessing probe plots in V3.5 and then it will show up during solving via "solver parameters - Plot while solving"
2 decades ago
22 sept. 2010, 15:58 UTC−4
Hi again,
Yes Ivar, I've read about postprocessing probe plots in the doc,But as far as I know there is a note in the doc that says you cannot vary parameters that control the geometry values through the parametric solver.I vary my geometry variable automatically by using the SolidWorks by using Geometric Parametric Sweep dialog box available from the SolidWorks Connection in the File menu.There is no Plot while solving option in that case or at least I can't find it.what do you suggest now?
Thanks alot
Azar
Hi again,
Thanks alot
Azar
2 decades ago
22 sept. 2010, 16:04 UTC−4
then probably you cannot do it in 3.5 I did not use that many CAD links that way, it's easier in V4 anyhow but OK you need to get the new version (and to learn how to use it)
2 decades ago
22 sept. 2010, 16:14 UTC−4
Ok then Thank you very much for your comments.
Still thinking
Azar
Still thinking
Azar
