Moving Wall boundary condition
Hi All,
Does anyone know what the deal is with the moving wall boundary condition in the Navier-Stokes app? What parameters can one enter into the wall velocity? Can you just put numbers for the vector components, or can you put equations with the independent invariables (like coordinate variables, time)? I would like to enter an equation so that the wall "moves" like a propagating wave in time. Also, what does this mean for the mesh? I used to have 3.2 and my method of simulating a moving interior boundary was by moving the mesh using ALE. Thanks for any feedback!
Robert
2 Replies Last Post 23 sept. 2010, 15:54 UTC−4
Posted: 2 decades ago 22 sept. 2010, 16:02 UTC−4
well now are you in 3.5 or 4 or ? It helps us others out here to tick the version.
Normally in Comsol you can use any equation anywhere, provided it can be solved with previously defined vriables/parameters, or variables found during the solving process
Hi well now are you in 3.5 or 4 or ? It helps us others out here to tick the version. Normally in Comsol you can use any equation anywhere, provided it can be solved with previously defined vriables/parameters, or variables found during the solving process -- Good luck Ivar
Posted: 2 decades ago 23 sept. 2010, 15:54 UTC−4
What is your current version? If it's version 3.5a, I believe that you would use ALE as you described (although I don't have much experience with that version). With the 4.0 version, it sounds like you would need to use the fluid-structure interaction physics (which has ALE mesh motion built in). This requires the additional structural mechanics module or possibly the MEMS module.
