Comsol 5 in 4.4
I want to open the model created using comsol 5 in comsol 4.4 Can anyone suggest me any ideas? Thanks
2 Replies Last Post 14 déc. 2015, 17:49 UTC+1
Krishnaswamy Veluswamy
Posted: 9 years ago 13 déc. 2015, 13:26 UTC+1
There is an way of exporting the model- geometry, right click the geometry in the skeleton and choose export. i have only 5.0 in laptop, and i can export to couple of versions in 4 and an single version in 3.
When u try to do that, change the "compatible with versions" to an lower value, which might work.
For the entire model, save it as an Java file and open in older versions, which might work. unless u have used all functions that are in the 4.4 rather than new ones in 5.0.
Post your feedback.
All the best.
Hi, There is an way of exporting the model- geometry, right click the geometry in the skeleton and choose export. i have only 5.0 in laptop, and i can export to couple of versions in 4 and an single version in 3. When u try to do that, change the "compatible with versions" to an lower value, which might work. For the entire model, save it as an Java file and open in older versions, which might work. unless u have used all functions that are in the 4.4 rather than new ones in 5.0. Post your feedback. All the best.
Posted: 9 years ago 14 déc. 2015, 17:49 UTC+1
Yeah i exported the geometry and added the physics separately.
Thanks!
Hi, Yeah i exported the geometry and added the physics separately. Thanks!
