4 oct. 2010, 17:40 UTC+2
yeps
1 If you are not admin, talk to your admin about that
2 if you are admin or your admin cannot solve the issue, open a ticket with support comsol they are good at solving these issues usually
JF
yeps
JF
28 nov. 2010, 02:24 UTC+1
Jones,
Thank you for your help.
For others that are running into the same problem:
It turns out that for the mphstart function to work, Comsol must be installed directly to the C drive. This is the default, but if you change the installation directory from C:\Comsol40a to C:\Program Files\Comsol40a you will run into this cs.root issue. Just uninstall and reinstall to C:\Comsol40a.
Jones,
28 nov. 2010, 08:46 UTC+1
the best, is to get hands on the 4.1 and install the new patch they gave out a few days ago, see the main web site
9 janv. 2014, 15:31 UTC+1
Hi everyone,
I was having the same problem with the following output on COMSOL4.3b and COMSOL4.4
c:\Program Files\COMSOL\COMSOL43b\demo>java -jar start.jar
Exception in thread "main" java.lang.ExceptionInInitializerError
at com.comsol.model.util.ModelUtil.connect(Unknown Source)
at StartPoint.main(StartPoint.java:13)
Caused by: java.lang.RuntimeException: Not possible to determine the installation path 'cs.root'.
at com.comsol.systemutils.SystemUtil.c(Unknown Source)
at com.comsol.systemutils.SystemUtil.getCsRoot(Unknown Source)
at com.comsol.systemutils.SystemUtil.<clinit>(Unknown Source)
... 2 more
Installing COMSOL to C:\COMSOL solved the problem!
Hi everyone,
at com.comsol.systemutils.SystemUtil.(Unknown Source)
... 2 more
28 mai 2014, 18:36 UTC+2
Update:
Modify your code and use:
import com.comsol.systemutils.SystemUtil;
System.out.println(SystemUtil.getCsRoot());
System.setProperty("cs.root", "C:\\COMSOL\\COMSOL43b");
Update:
8 years ago
9 déc. 2016, 10:44 UTC+1
although this is a pretty old issue, it still exists.
I am using COMSOL 5.2a and stumbled into the issue when building a release version of my java program that uses the COMSOL java interface for fem modeling. In Eclipse everything works fine, but when I packed jar files and wanted to start them including the COMSOL libraries in the classpath I got the same error message.
Thanks to Matthias for his hint to use the system properties to define cs.root.
I have observed that both SystemUtil.getSysProps() and SystemUtil.getCsRoot() throw the exception and unfortunately I was not able to catch the exception, so one have to set cs.root before.
Following workaround worked well for me, I hope it will be stable against version updates. I search the java path for a directory that contains 'Multiphysics' and use that as cs.root:
Properties props = System.getProperties();
String path = props.getProperty("java.class.path");
int pos=path.indexOf("Multiphysics");
int sem1=path.substring(0, pos).lastIndexOf(";");
System.setProperty("cs.root", path.substring(sem1+1,pos+12));
System.out.println("cs.root set to "+SystemUtil.getCsRoot());
But let's be aware that this is only a workaround. I guess that there is some bug in the code that causes the problem to identify the path. My guess: It is either the backslash\ or slash/ in the path or filenames containing spaces (I have windows, so Comsol in installed under 'program files')
