deformed geometry - interface velocity
Posted 8 janv. 2016, 15:54 UTC+1 Heat Transfer & Phase Change Version 5.2 1 Reply
I have a problem (2d-axy) where an interface moves depending on thermal fluxes with a normal velocity of the mesh Vinter.
BUT I have also to impose a mesh velocity Vimposed along an axis on the same boundary.
I cannot find a solution to this problem.
The more accurate solution that I found for the moment is
Prescribed Mesh Velocity:
vr=Vinter*nr
vz=Vinter*nz-Vimposed
with weak constraints
The computation can't start
Some ideas?
Best regards
Julien
vr=Vinter*nr
Some ideas?
Best regards
Julien
1 Reply Last Post 8 janv. 2016, 17:30 UTC+1
