several parametric sweep simultaneously
Mohammadreza Barzegaran
Hi everybody
Is it possible to have several parametric sweep solution simultaneously in comsol 3.5a? if yes please write the command
4 Replies Last Post 5 déc. 2010, 09:20 UTC+1
Posted: 1 decade ago 4 déc. 2010, 13:45 UTC+1
from what I remembered, only one (without passing through matlab) but you could have several parameter for the sae sweep, check the doc
of the type
param1 param2 ...
1 1.1 2 2.2 3 3.3
giving
param1 = {1 2 3}
param2 = {1. 2.2 3.3}
Hi from what I remembered, only one (without passing through matlab) but you could have several parameter for the sae sweep, check the doc of the type param1 param2 ... 1 1.1 2 2.2 3 3.3 giving param1 = {1 2 3} param2 = {1. 2.2 3.3} -- Good luck Ivar
Posted: 1 decade ago 4 déc. 2010, 15:56 UTC+1
I knew this method ;but by using this method only value the first parameter changes the second is fake
Hi Thanks I knew this method ;but by using this method only value the first parameter changes the second is fake
Posted: 1 decade ago 4 déc. 2010, 16:24 UTC+1
Mohammadreza,
I used this method and it works properly. You might want to check it in a simple place like expressions and plot it Vs a parameter.
Again, if your parameters are vectors say {a} and {b}
So in GUI, they are
a1 b1 a2 b2 a3 b3...etc
Good luck,
Stephan
Mohammadreza, I used this method and it works properly. You might want to check it in a simple place like expressions and plot it Vs a parameter. Again, if your parameters are vectors say {a} and {b} So in GUI, they are a1 b1 a2 b2 a3 b3...etc Good luck, Stephan
Posted: 1 decade ago 5 déc. 2010, 09:20 UTC+1
there is one limitation: the first parameter must always be monotonously increasing (or decrasing)
Hi there is one limitation: the first parameter must always be monotonously increasing (or decrasing) -- Good luck Ivar
