Create arbitrary distribution of circles via Livelink for Matlab
Hallo Comsol Community
First of all, since i am very new to this discussion forum please excuse any 'unclearness' in the way i will try to express my problem.
I am currently using the matlab livelink feature of comsol 4.1 for creating a 2D geometry that consists of arbitrarily posistioned circles.
The way i am trying to do this is by the following matlab script:
model = ModelUtil.create('Model');
geom1 = model.geom.create('geom1',2);
index=1
x=randi([-100 100],30,1)
y=randi([-100 100],30,1)
index
for i=1:1:size(x,1)
c(i)= geom2.feature.create((strcat('c',i)),'Circle');
c(i).set('r',1);
c(i).set('pos',[x(i) y(i)]);
geom2.run;
index=index+1
end
geom2.run;
mphgeom(model,'geom2');
1) I really do not understand why each geometric element has to be under a different variable name.Right now i am incorporating all my circles inside the matrix called c and i do not know if this is correct.
2) If i run the same script with
x=randi([-100 100],40,1)
y=randi([-100 100],40,1) instead of
then i get an error on the geom2.run function that i also cannot explain.
1 Reply Last Post 16 mai 2012, 01:28 UTC+2
Hello Orestis Vardoulis
Posted: 1 decade ago 16 mai 2012, 01:28 UTC+2
I have a similar issue. I was able to make this into an array in 3.5a but in 4.2 I have not figured out a way to get around this naming issue.
